igor_dulatov
Nov 01, 2009Aspirant
PS3 Media Server for ReadyNAS PRO
I have made addon PMS for readynas pro. it support transcoding in realtime (mkv can play at PS3). Addon include java, mplayer, mencoder, ffmpeg, tsmuxer and PMS. If anybody want to test it - downloa...
Ushman
Jan 02, 2010Aspirant
Lew,
The value of the C-200 is definitely in its ability to play nearly ever format imaginable without the need for any additional transcoding or file manipulation. The PS3 is great and like you said the games are gravy but it does have its shortcomings, but I would have to say (for me) the biggest drawback is that the PS3 can't play MKV files natively, which is why this add-on is so great (once all the kinks are worked out).
The C-200 can play MKV's natively without having to transcode them into the m2ts container (like you have to do with the PS3). If you have alot of MKV files then this feature may be attractive for you rather than spending extra time transcoding. Also, the C-200 can handle DTS audio streams, so this is another big advantage over the PS3 which cannot stream DTS (even though it can play DTS from disc).
One other little thing I like about the C-200 is that you can actually stream audio to your home stereo using the little LCD screen on the front without having to turn the TV on (like the PS3). My 50 inch plasma sucks a lot of juice when it is on, so having it on just to control song selection is a waste of energy/money.
I agree with you, I could just get the C-200 and then worry about blu-ray later, but this PS3MS add-on almost makes things equal (except I still won't be able to watch MKV's with DTS audio unless I transcode the DTS to AC3). The C-200 is just still too expensive compared to a $299 PS3. If the price comes down, I will potentially consider replacing one of my PS3's for a C-200. So for me, it boils down to which will come first, C-200 price drop or MKV compatibility with PS3. This add-on has me leaning away from the C-200. Have you installed this add-on yet? Do you have it working on all your files? Are you going to go with the C-200?
Cheers,
Ushman
Cheers,
Ushman
