igor_dulatov
Nov 01, 2009Aspirant
PS3 Media Server for ReadyNAS PRO
I have made addon PMS for readynas pro. it support transcoding in realtime (mkv can play at PS3). Addon include java, mplayer, mencoder, ffmpeg, tsmuxer and PMS. If anybody want to test it - downloa...
linkup1
Jan 03, 2010Aspirant
Hello Sir,
I didn't know you needed an additional program on the Pro to let the PS3 run movies from it. Learn and life. Will tackle that when I have the Pro set up.
There is a PS3 Media Server program I run on my Vista PC and it is the same as or works with the NAS version? Will try to find the program.
I checked out Iboum. Can I believe their ratings? The c-200 was about 9th, the WD Live TV or whatever it is called was first.
http://www.iboum.com/sort/media-players-sort-rating.php
If people aren't ripping in native format, what format are the using for HD or BR to retain the quality? I am unhappy with most AVI and WMV movies I have seen due to compression leading to extreme pixelation. I hate the block blacks and solid areas.
As far as space, I am starting with 6 2TB Hitachis drives...that should hold a few movies, however it isn't for my movies, it is for my photos.
I am also going to build a Winserver with an old box of mine and that will probably be another 4+ 2TB drives, but want to use it for a backup for the first system.
I thought some of the media players ran N or double N or whatever it is called and the claim to be able to play hires videos? Is that marketing hype vs. reality?
I ordered a couple 50' CAT6 cables for my PS3 and whatever I buy for the second location. Will need to put a hole in the floor or two outside walls to get from A to B.
Since I haven't even bought a BR yet as I had no need before buying the PS3 which came with none. So if I want to rip the BR disks to play on my PS3 or on my C-200 or whatever, what software would you use to RIP/convert to format X?
Thanks!
Thanks!
