igor_dulatov
Nov 01, 2009Aspirant
PS3 Media Server for ReadyNAS PRO
I have made addon PMS for readynas pro. it support transcoding in realtime (mkv can play at PS3). Addon include java, mplayer, mencoder, ffmpeg, tsmuxer and PMS. If anybody want to test it - downloa...
mathijzz
Mar 05, 2010Aspirant
petese wrote: I think i did uninstall old one version (1.1).
But if you can reupload this again (i have problem with old one download of this v1.1), i will try to uninstal both then install v1.1 uninstall and install again v2.1, maybe its the way for my "PMSFORREADYNAS" problem.
In frontview i dont see "PMSFORRAEDYNAS" share, and when i'm trying to create this share saying "share already exist".
It's a log: "The paths for the shares listed below could not be found. Typically, this occurs when the ReadyNAS is unable to access the data volume. PMSFORREADYNAS".
Indicator light is fine but PS3 still don't "see" server.
Just like petese i have a ReadyNAS NVX and my PS3 also doesn't see the PMS Server. Is this addon not compatible with the NVX?
