igor_dulatov
Nov 01, 2009Aspirant
PS3 Media Server for ReadyNAS PRO
I have made addon PMS for readynas pro. it support transcoding in realtime (mkv can play at PS3). Addon include java, mplayer, mencoder, ffmpeg, tsmuxer and PMS. If anybody want to test it - downloa...
igor_dulatov
Oct 17, 2010Aspirant
New version released!
changes:
1. Separated 3 packages: Mplayer (contain mplayer,mencoder,ffmpeg,tsmuxer) - need only for support transcoding, Java (jre 1.6.0_22) and PS3 Media server.
2. New PS3 Media server version 1.20.412
Mplayer
contain mplayer, mencoder, ffmpeg and codecs - all compiled at ReadyNas, and tsmuxer
you need install if want transcoding support by PMS
JRE4ReadyNas
Installs Java to ReadyNas. and save in /etc/default/services two env.:
JRE4READYNAS_JAVA_HOME - home directory for java
JRE4READYNAS_JAVA_VER - version number of java
if you want to lunch java programs do this
. /etc/default/services #read env.
$JRE4READYNAS_JAVA_HOME/bin/java program.jar # start java program
Must be installed for PMS working
PS3MediaServer
add default language support (it write in pms.conf parameters "language" and "mencoder_audiolang")
ru - russian, en - english and others...
If video file contain dif.languages PMS select lang.for playing from it parameter
All packages install in /c/addons-config (network address \\nasservername\addons-config)
I think 3 packages is better for using and updating
download:
Java http://depositfiles.com/files/abvzfe4uh
PMS http://depositfiles.com/files/e19w4dzdn
Mplayer http://depositfiles.com/files/zcteyrxps
Before install i recommend to remove previous version
P.S. If somebody find web configurator for PS3 Media Server - tell me and i include it in next package
changes:
Mplayer
JRE4ReadyNas
PS3MediaServer
download:
