igor_dulatov
Nov 01, 2009Aspirant
PS3 Media Server for ReadyNAS PRO
I have made addon PMS for readynas pro. it support transcoding in realtime (mkv can play at PS3). Addon include java, mplayer, mencoder, ffmpeg, tsmuxer and PMS. If anybody want to test it - downloa...
kylen
Nov 27, 2010Aspirant
I have the ultra 6 and for the most part works great on 1080p HD mkvs. Only for 1 or 2 has it stuttered a bit (just playing with default options). If you have subtitles and need to play from the "Transcode" subfolder, this is less reliable--I have found this seems to stutter quite a bit more often.
The main issue I have found is there is no way to skip forward or back, and if you try, it will mess up and mark the file as "Corrupted Data" on he PS3. Even if you restart PS3 it doesn't fix it--need to restart the PMS and start the mkv file again from the beginning. The 1.5x playback works but that is as fast as you can go forward.
