igor_dulatov
Nov 01, 2009Aspirant
PS3 Media Server for ReadyNAS PRO
I have made addon PMS for readynas pro. it support transcoding in realtime (mkv can play at PS3). Addon include java, mplayer, mencoder, ffmpeg, tsmuxer and PMS. If anybody want to test it - downloa...
kylen
Dec 15, 2010Aspirant
cktb2793 wrote: great thank you...... so once I do that.... the files will just show up on my ps3? Do the files that always showed up on ps3 still fast forward and rewind and the full range of speeds?
You will see a new PS3 Media Server icon on the XMB (A Green Triangle). In the config for PMS you need to tell it what dir to share--it will find all files off of that--the config is in the Installed Addons menu. Like anything you watch via PMS, you can really only FF 1.5x after that it just freezes--there is no rewind. It's not like watching stuff from other media servers since PMS is doing the transcoding instead of having the PS3 do it. I believe the normal DLNA plugin for the readynas gives you full FF/RW if you use the VIDEO_TS folder instead of an ISO, but it's not as clean--you would need to play each vob section.
