igor_dulatov
Nov 01, 2009Aspirant
PS3 Media Server for ReadyNAS PRO
I have made addon PMS for readynas pro. it support transcoding in realtime (mkv can play at PS3). Addon include java, mplayer, mencoder, ffmpeg, tsmuxer and PMS. If anybody want to test it - downloa...
kylen
Dec 16, 2010Aspirant
I'm not at home so I can't check, but XMB is the PS3 Cross Media Bar--basically their menu system. When you go to Video, you would see a list of all of the DLNA servers it found. You will see one that's a Blue Box with an R or an N (can't remember) and that is the ReadyNas one. There will also be one with a Green Play triangle as the icon--that is the Playstation Media Server one. On the PS3 Media Server one, the ISO's should be listed. You may want to try rebooting the NAS to see if that helps--I remember at one point I wasn't seeing my ISOs, but then I was.
As for Video_TS, I thought the ReadyNAS DLNA one did those, but I'm not sure--I would need to check again.
