igor_dulatov
Nov 01, 2009Aspirant
PS3 Media Server for ReadyNAS PRO
I have made addon PMS for readynas pro. it support transcoding in realtime (mkv can play at PS3). Addon include java, mplayer, mencoder, ffmpeg, tsmuxer and PMS. If anybody want to test it - downloa...
cktb2793
Dec 21, 2010Aspirant
kylen wrote:
cktb2793 wrote: No matter what I do....... .ISO files don't show up on my PS3......I don't get it.
I even just put it right in the main video folder and no other sub folders and it still doesn't show up...... any ideas???
I don't know what to tell you--it it working fine for me. Did you create the ISO's yourself? If not, try using DVDDecrypter to rip a DVD to an ISO and see if that file works. Also, you are looking at the folder via the PS3 Media Server item (Green Play Triangle) from the PS3 menu and not the ReadyNAS one (White N with Blue Background) right? For me, the ReadyNAS one works for VIDEO_TS folders but not ISOs.
Yes, I created the ISO's myself. I've been looking in the Ready Nas item......... I don't have a PS3 Media Server Green Play Triangle.....I even just did a rescan on the PS3 and still nothing. What do you think I did wrong? My ReadyNas says the PS3 media server is installed
My Frontview shows a Media Directory box and a Default language box for the PS3 Media Server and they are both blank.......is that correct?
