igor_dulatov
Nov 01, 2009Aspirant
PS3 Media Server for ReadyNAS PRO
I have made addon PMS for readynas pro. it support transcoding in realtime (mkv can play at PS3). Addon include java, mplayer, mencoder, ffmpeg, tsmuxer and PMS. If anybody want to test it - downloa...
kylen
Dec 22, 2010Aspirant
cktb2793 wrote: My Frontview shows a Media Directory box and a Default language box for the PS3 Media Server and they are both blank.......is that correct?
Those should be /media and en
You can try un-clicking the box and click Save to stop the server and click the box and Save to start the server again.
You may even need to reboot the ReadyNAS if that doesn't successfully restart the server. You did install all three pieces, right? First the JRE plugin then the PMS plugin and then the MPlayer plugin?
