igor_dulatov
Nov 01, 2009Aspirant
PS3 Media Server for ReadyNAS PRO
I have made addon PMS for readynas pro. it support transcoding in realtime (mkv can play at PS3). Addon include java, mplayer, mencoder, ffmpeg, tsmuxer and PMS. If anybody want to test it - downloa...
cktb2793
Dec 22, 2010Aspirant
kylen wrote:
cktb2793 wrote: I've done everything.......... /media and en are in the boxes......... I've turned PSMedia off and back on......... I've rebooted the ReadyNas..... I still do NOT see the PSMedia player in the PS3....... all I see is the ReadyNas and NO .ISO files.
I don't understand what's wrong.........please help.
Did you install any other Java add-ons that could be conflicting?
Did you install ssh access to the box (if so you could ssh in and do a ps to see if the pms process is running)?
Maybe try removing all 3 add-ons and start over.
First install JRE4ReadyNas_1.0.bin
Then PMS4ReadyNAS_3.0.bin
Then MPlayer4ReadyNas_1.0.bin
I think by default it starts with settings /media and ru -- it should still start with those settings (and probably still find your files). The fact that you don't see the PMS server on your PS3 is the bigger problem--then you can worry about it not finding the files.
The only add-ons I have are those 3 and Readynas Remote. I'll try removing those 3, rebooting, then re-adding in the order you suggested. BTW, my router is a Netgear WNDR37AV and I have new PS3 106gb's...... not sure if any of that matters.
