Holster100
Sep 13, 2015Aspirant
Purchase 8 camera licence
Hi can anyone tell me how i purchase a 8 cam licence for RND4000? I'm in Melbourne Australia. Thanks
BrianL2
Sep 14, 2015NETGEAR Employee Retired
Hi Holster100,
ReadyNAS Surveillance is only available to ReadyNAS x86 (4.2.x)and OS 6 units. You can check this article for more information.
Hope this helps!
Kind regards,
BrianL
NETGEAR Community
Holster100
Sep 14, 2015Aspirant
Sorry i put the wrong model. I have the readynas 104 with Surveillance app already installed.
Just need to buy the licences.
Thanks
- BrianL2Sep 14, 2015NETGEAR Employee Retired
Hi Holster100,
You can get the 2x four-camera license (RNNVR04L-10000S) at megabuy.com.au
Kind regards,
BrianL
NETGEAR Community
- Holster100Sep 14, 2015Aspirant
Thanks Brian.
Sorry just one more question.
Is there another trial version that lets you test more than one camera?
I have 8 HD cams and want to make sure the nas will handle them ok.
Cheers
Hi Holster100,
Under the home category, there's only 1 camera license included that we can also consider for trial use. Kindly check our compatibility list to see if your HD cameras will work fine.
Kind regards,
BrianL
NETGEAR Community
