dsm1212
Mar 13, 2015Apprentice
Qbittorrent update
The qbittorent included in the readynas distribution is quite old (2.9.8-1) and buggy. It appears there are newer compatible ubuntu built distributions available. For example, see here: http://www.tec...
chrispeachey
Mar 11, 2016Aspirant
Hello, Iv been looking for a solution to this for a while, i have a background in IT but never gone into coding etc. can someone point me in the right direction to updating qbittorrent on my nas? i see these instructions here but dont know how to get to this stage. have very basic command promt skills so once rolling i should be ok.
BrianL2
Mar 11, 2016NETGEAR Employee Retired
Hi chrispeachey,
The latest Qbittorrent add-on version for OS 6 is 1.0.3. Do you have the same version installed in your machine? Are you having problems too?
Kind regards,
BrianL
NETGEAR Community Team
