dsm1212
Mar 13, 2015Apprentice
Qbittorrent update
The qbittorent included in the readynas distribution is quite old (2.9.8-1) and buggy. It appears there are newer compatible ubuntu built distributions available. For example, see here: http://www.tec...
ATCIS
Mar 15, 2016Tutor
chrispeachey wrote:these instructions? i dont know how to get to this stage? hence why i asked for instructions the following post...
So, are you telling me you are stuck at STEP 1 ?
If so, have you enabled ROOT access on the ReadyNAS in question?
What operating system are you using to SSH into your ReadyNAS?
chrispeachey
Mar 17, 2016Aspirant
Q1 - yes... im telling you im stuck on step 1... hence why iv asked for instructions to get to this stage several times now... i just want a quick... you enable this, you reset your nas and boot into this mode... you then install this program and bam.. you are now at step 1... is it that hard?????
Q2 - NO but i can, iv seen that floating around in the setting before
Q3 - as stated before i have not used SSH... so are you refering to the OS as in windows/mac etc? or the specific software im using to SSH? BTW its windows 7 64bit.
