Nullius
Sep 05, 2011Aspirant
RAIDiator in VMWare or VirtualBox
Hi, One of my clients (small size business) has just bought a Ultra 6 Plus NAS. Since I'm going to be the one maintaining it, I'd like to be sure my changes to the system won't harm it (and especi...
WhoCares_
May 18, 2012Mentor
Debian Etch for the x86 based ReadyNAS line, and yup, most things should work although you may need to recompile some stuff. If you're familiar with Debian then you can check what's already on the ReadyNAS using the dpkg tool and change your VM accordingly. Since the GPL sources for the packages used are available that shouldn't be too hard.
-Stefan
-Stefan
