dagmarian
Apr 18, 2016Guide
Dokuwiki
How do I update dokuwiki on my ReadyNAS? Every time I click on any dokuwiki link including relating to the numerous update messages, Safari on my Mac takes me to a Dokuwiki internet page and if I do...
- May 18, 2016
What you need to do is:
- Go to the Admin interface of Dokuwiki
- Click on the "Extension manager" entry
The either
- In the extension manager switch to the "Search and Install" tab
- Search for "DokuWiki upgrade plugin"
Or:
- In the extension manager switch to the "Manual install" tab
- Enter the URL https://github.com/splitbrain/dokuwiki-plugin-upgrade/zipball/master in the "Install from URL" box
- Click on "install"
When the installation of the "DokuWiki upgrade" plugin is finished, go back to the "Admin" page. There you now have an entry named "Wiki upgrade" in the "Additional Plugins" section. Click on that and you'll be taken through the upgrade process.
-Stefan
dagmarian
May 11, 2016Guide
Getting nowhere with this.....
WhoCares_
May 18, 2016Mentor
The either
Or:
-Stefan
- dagmarianMay 20, 2016Guide
Bingo!
Many thanks for these instructions. Worked seamlessly - I am most grateful.
- JohnRoMay 23, 2016NETGEAR Employee Retired
Hi dagmarian,
Glad to know you got it working! If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Thanks,
