hansmuster
Jan 15, 2016Aspirant
DokuWiki installation not quite complete on RN102
DokuWiki is one of the apps included with the RN102 (and other models, I presume). It's a nice little Wiki with a small feature set and you'll be up and running in no time.
However, the installation as performed by the RN102 in the apps panel will not be quite complete. You will see no admin button, can not add any users and will be confronted with a long list of updates you should apply.
Before using the newly installed DokuWiki you should apply its own installation script. You do so by opening the install.php in your browser. Open this address with your browser: http://192.168.1.67/dokuwiki/install.php (where 192.168.1.67 is the IP address of your RN102).
It took me a while to find out that the install.php was necessary and how to find it. I think it might be useful if the RN102 could invoke the install.php as part of the installation procedure.
- JennCNETGEAR Employee Retired
Hello hansmuster,
Thank you for the feedback.
Hopefully the developer will see this feed back. You can also check their website at https://rnxtras.com/ and see if there is a way to let them know there. ReadyNAS Xtras is one of the app developers registered with NETGEAR.
- hansmusterAspirant
JennC -
I managed to find an eMail address on their web site and submitted a link to this thread. However, I haven't heard of them since.
BTW, this thread in this forum is a direct consequence of the incomplete installation: dokuwiki - no admin button
Kind regards
Hans
