TeknoJnky
Jul 03, 2017Hero
installing handbrakecli 1.0.7
I am trying to get handbrakecli 1.0.7 installed. Installing via apt-get installs and older version, I beliieve 0.9.9 1.0.7 shows up as experimental @ https://packages.debian.org/search?keywor...
TeknoJnky
Jul 03, 2017Hero
ffmpeg is already installed so that is not the problem, so much as the version dependencies requried by the experimental handbrakecli.
There doesn't seem to be any packagages for these required versions, for debian jessie.
dmacleo
Jul 03, 2017Guide
thought there were backports of them but not much experience installing on deb systems.
do seem to remember there was a multiarch file transitional package that needed to be applied to some deb systems for these items but I don't truct my memory there, sorry
maybe if I get chance tomorrow I can wipe a vps install jesse and see and go from there, unsure if will have chance though.
maybe then can get some insight
- TeknoJnkyJul 03, 2017Hero
ok thanks, I am getting the feeling that I would need to compile each of these dependencies from source, which I may as well compile handbrakecli too. But I didn't want to get that deep into it and was hoping for a simpler solution.
- dmacleoJul 03, 2017Guide
have not had chance to dig but this was one backport I was thinking of
https://packages.debian.org/jessie-backports/libx264-148
https://wiki.debian.org/ffmpeg
FFmpeg is not available on Debian 8 Jessie, but in Backports. To find out which deposit the package is available, look here: debpkg:libav or here debpkg:ffmpeg . It also possible to compile it by following the instructions available here: https://trac.ffmpeg.org/wiki/CompilationGuide/Ubuntu .
