FGIT
Feb 06, 2018Aspirant
Is PLEX compatibile with ReadyNAS 420 Series
Neither ReadyNas RN422 nor 424 are the PLEX compatibility list. Yet PLEX is listed in the Add-on Applications section of the ReadyNAS 420 Series. If one also consider that RN31X models are on the P...
- Feb 06, 2018
I got 2x 1080 video streams on the 42x series. If there are other tasks running, then 1x 1080p stream easily.
A while ago when I was testing plex with 31x, I think I barely got 1x 720p stream.
Feb 06, 2018Guru - Experienced User
wrote:
any os 6 app should work on any os6 device
No, some can be limited to ARM-only or X86-only.
OOM-9
Feb 06, 2018NETGEAR Expert
- FGITFeb 14, 2018Aspirant
I did install PLEX myself and even if I have not done major testing I do have not encountred any issue. Enabling DLNA within PLEX I can even stream to an TV that has no specific PLEX support. So I would say the system appear to work reasonably well.
Thanks for the reassurance that I would not do major damages when installing.
