McGarnagle
May 09, 2017Aspirant
NZBGet unpack not working
Hi I currently have NZBGet set up so that all new downloads are downloaded into an "Incomplete" folder. I've then set NGBGet so that complete downloads are moved to a "Complete" folder, with sub...
JBDragon1
Jun 17, 2017Virtuoso
unrar comes with NZBGet. If it's not working, it's more then likey that your directory settings are WRONG!!! So the settings in PATH, the Main Directory, is the directory location NZBGet is as. For example, I have NZBGet installed here: /apps/nzbget/
As Unrar is in NZBGet's main directory. Some of the other important things are WebDirectory. Which for me is /apps/nzbget/webui as that's where that is located for me. A folder inside the NZBGet folder. If you screw these up, the program will fail to even run. You really want to make sure everything is linked to where it actually is.
The other paths like Distination Directory I have in /data/Media/NZBGet/Complete or Inter Dir in /data/Media/NZBGet/Intermediate and so forth. The Media folder is where I have all my content located at. Made that easy to access my Maping that drive to Z: Click on that and I go right to my Media folder on my NAS like any other HDD on my computer.
McGarnagle
Jun 20, 2017Aspirant
Im fairly certain that the unrar directory is correct. According to the log it veryfies the .rar files during post process.
The end of the log is as follows:
INFO Tue Jun 20 2017 19:04:09 Collection dark.matter.s03e01.1080p.web.x264-heat added to history
ERROR Tue Jun 20 2017 19:04:09 Unpack for dark.matter.s03e01.1080p.web.x264-heat failed.
INFO Tue Jun 20 2017 19:04:09 Second unpack attempt skipped for dark.matter.s03e01.1080p.web.x264-heat due to par-check not repaired anything
INFO Tue Jun 20 2017 19:04:08 Repair not needed for dark.matter.s03e01.1080p.web.x264-heat/7d7ef4023edfb1e08c89c1db079c756f
DETAIL Tue Jun 20 2017 19:04:08 Par: 1 recovery blocks will be used to repair.
DETAIL Tue Jun 20 2017 19:04:08 Par: an excess of 89 recovery blocks.
DETAIL Tue Jun 20 2017 19:04:08 Par: Repair is possible.
DETAIL Tue Jun 20 2017 19:04:08 Par: 90 recovery blocks available.
DETAIL Tue Jun 20 2017 19:04:08 Par: 901 out of 902 data blocks available.
DETAIL Tue Jun 20 2017 19:04:08 Par: 29 file(s) are ok.Tue Jun 20 2017 19:04:08 Par: 1 file(s) are missing.
DETAIL Tue Jun 20 2017 19:04:08 Par: Repair is required.
DETAIL Tue Jun 20 2017 19:04:08 Par: Scanning extra files:
INFO Tue Jun 20 2017 19:04:08 Verifying file dark.matter.s03e01.1080p.web.x264-heat.sfv
INFO Tue Jun 20 2017 19:04:07 Verifying file dark.matter.s03e01.1080p.web.x264-heat.rar
INFO Tue Jun 20 2017 19:04:06 Verifying file dark.matter.s03e01.1080p.web.x264-heat.r26
INFO Tue Jun 20 2017 19:04:05 Verifying file dark.matter.s03e01.1080p.web.x264-heat.r25
INFO Tue Jun 20 2017 19:04:04 Verifying file dark.matter.s03e01.1080p.web.x264-heat.r24
INFO Tue Jun 20 2017 19:04:03 Verifying file dark.matter.s03e01.1080p.web.x264-heat.r23
INFO Tue Jun 20 2017 19:04:02 Verifying file dark.matter.s03e01.1080p.web.x264-heat.r22
Something is failing here. I can unrar manually, by navigating to the NAS download directory and extracting with rar installed on Windows.
