McGarnagle
May 09, 2017Aspirant
NZBGet unpack not working
Hi I currently have NZBGet set up so that all new downloads are downloaded into an "Incomplete" folder. I've then set NGBGet so that complete downloads are moved to a "Complete" folder, with sub...
JBDragon1
Jun 20, 2017Virtuoso
In the past having issues, it was normally some little thing that was not right. You may glace over it and not realize that was the problem all along. I've been using the program long enough and installed in a few times and gone over the settings many times over, I would hope it would work as it should and it does. Dark Matter is one Sonarr looks for and sends what it needs to for NZBGet which has downloaded without issue and Unrar piece of cake. It's really amazing how fast it can find it, download and and have it all processed from the NAS, shortly PLEX shows it as there ready to watch. All without having to do anything.
I still think it's a PATH thing. Maybe not with Unrar but with one of your other directly links.
I think it's something either in the PATHS, Check and Repair, or Unpack settings. The simple fact it's working on your Windows computer just fine makes it sound like something is not correct on NZBget on the NAS. Without seeing what's really going on, it's hard to just guess. All I can say is it works PEFECT for me these days. I can't ask it to work any better then it is. I can say there are some setting differances from the NAS to Windows. Also from one version to a newer version. It's all guessing at the point.
McGarnagle
Jun 22, 2017Aspirant
I've noticed that its giving the following erroe:
Thu Jun 22 2017 19:20:57 Unrar error code: 64 INFO Thu Jun 22 2017 19:20:57 Unrar: Try `unrar --help' or `unrar --usage' for more information. INFO Thu Jun 22 2017 19:20:57 Unrar: unrar: invalid option -- 'y'
Is there a way to lookup what error code 64 means?
