dsm1212
Mar 13, 2015Apprentice
Qbittorrent update
The qbittorent included in the readynas distribution is quite old (2.9.8-1) and buggy. It appears there are newer compatible ubuntu built distributions available. For example, see here: http://www.tec...
chrispeachey
Mar 15, 2016Aspirant
no go then...
ATCIS
Mar 15, 2016Tutor
chrispeachey wrote:no go then...
Did you happen to try the step by step instructions provided five (6 including this one) posts ago? If so, and it did NOT work, please provide some additional details as to where things went wrong. . .
- chrispeacheyMar 15, 2016Aspirant
In case anyone else runs in to this same issue, I was able to answer my own question (since no one else chimed in). Here is how I did it:
- Upload qbittorrentr6_3.3.0_amd64.deb to a directory on the NAS of your choosing (I used /root)
- (Credit to h3nk3t for this idea from and earlier post) apt-get purge qbittorrent-nox (removes remnants of version 1.03)
- apt-get install qbittorrent-nox (updates qbittorrent-nox to version 2.9.x)
- dpkg -i qbittorrentr6_3.3.0_amd64.deb apt-get install -f <--- I'm not a Linux Guru, so I'm not sure that last part was required
- Profit !!!
these instructions? i dont know how to get to this stage? hence why i asked for instructions the following post...
- ATCISMar 15, 2016Tutor
chrispeachey wrote:these instructions? i dont know how to get to this stage? hence why i asked for instructions the following post...
So, are you telling me you are stuck at STEP 1 ?
If so, have you enabled ROOT access on the ReadyNAS in question?
What operating system are you using to SSH into your ReadyNAS?
i dont know SSH, iv heard about it. never done it... hence why id like some instructions.
