dsm1212
Mar 13, 2015Apprentice
Qbittorrent update
The qbittorent included in the readynas distribution is quite old (2.9.8-1) and buggy. It appears there are newer compatible ubuntu built distributions available. For example, see here: http://www.tec...
ATCIS
Mar 15, 2016Tutor
chrispeachey wrote:these instructions? i dont know how to get to this stage? hence why i asked for instructions the following post...
So, are you telling me you are stuck at STEP 1 ?
If so, have you enabled ROOT access on the ReadyNAS in question?
What operating system are you using to SSH into your ReadyNAS?
chrispeachey
Mar 15, 2016Aspirant
i dont know SSH, iv heard about it. never done it... hence why id like some instructions.
- ATCISMar 17, 2016Tutor
I asked you three (3) questions above. You answered zero (0). Try again. . .
