jarness17
Jun 13, 2019Aspirant
ReadyNAS 4220 - Status Degraded
Hi, We have a ReadyNAS 4220 in which the status is "Degraded". I have examined the logs and the mdstat.log reports that raid device is removed. Yesterday I reseated disk 12 and left it resyncin...
jarness17
Thank you for your reply. I've scheduled in to reboot in the morning so will see how I get on.
jarness17
Jun 14, 2019Aspirant
I rebooted the device this morning and it updated to the latest firmware although it is still stating degraded. The log is still showing 13 disks for some reason. I have copied the mdstat.log below if anyone can give any advice.
Thanks in advance!
Personalities : [raid0] [raid1] [raid10] [raid6] [raid5] [raid4] md127 : active raid6 sdi3[0] sde3[11] sdc3[16] sdh3[13] sdf3[17] sdg3[7] sdd3[6] sdb3[15] sda3[12] sdm3[3] sdl3[2] sdj3[1] 21435290624 blocks super 1.2 level 6, 64k chunk, algorithm 2 [13/12] [UUUUUUUUUUUU_] md1 : active raid10 sdj2[0] sdh2[11] sdb2[10] sdf2[9] sdc2[8] sde2[7] sdg2[6] sdd2[5] sda2[4] sdm2[3] sdl2[2] sdi2[1] 3139584 blocks super 1.2 512K chunks 2 near-copies [12/12] [UUUUUUUUUUUU] md0 : active raid1 sdi1[0] sde1[11] sdc1[16] sdh1[13] sdf1[17] sdg1[12] sdd1[6] sdb1[15] sda1[4] sdm1[3] sdl1[2] sdj1[1] 4190208 blocks super 1.2 [13/12] [UUUUUUUUUUUU_] unused devices: <none> /dev/md/0: Version : 1.2 Creation Time : Thu Oct 8 17:31:56 2015 Raid Level : raid1 Array Size : 4190208 (4.00 GiB 4.29 GB) Used Dev Size : 4190208 (4.00 GiB 4.29 GB) Raid Devices : 13 Total Devices : 12 Persistence : Superblock is persistent Update Time : Fri Jun 14 08:58:41 2019 State : active, degraded Active Devices : 12 Working Devices : 12 Failed Devices : 0 Spare Devices : 0 Consistency Policy : unknown Name : 43f61440:0 (local to host 43f61440) UUID : a7a7619c:7aaccfde:b80a3b50:6082776a Events : 1840063 Number Major Minor RaidDevice State 0 8 129 0 active sync /dev/sdi1 1 8 145 1 active sync /dev/sdj1 2 8 177 2 active sync /dev/sdl1 3 8 193 3 active sync /dev/sdm1 4 8 1 4 active sync /dev/sda1 15 8 17 5 active sync /dev/sdb1 6 8 49 6 active sync /dev/sdd1 12 8 97 7 active sync /dev/sdg1 17 8 81 8 active sync /dev/sdf1 13 8 113 9 active sync /dev/sdh1 16 8 33 10 active sync /dev/sdc1 11 8 65 11 active sync /dev/sde1 - 0 0 12 removed /dev/md/1: Version : 1.2 Creation Time : Wed Jun 12 14:49:29 2019 Raid Level : raid10 Array Size : 3139584 (2.99 GiB 3.21 GB) Used Dev Size : 523264 (511.00 MiB 535.82 MB) Raid Devices : 12 Total Devices : 12 Persistence : Superblock is persistent Update Time : Fri Jun 14 05:22:10 2019 State : clean Active Devices : 12 Working Devices : 12 Failed Devices : 0 Spare Devices : 0 Layout : near=2 Chunk Size : 512K Consistency Policy : unknown Name : 43f61440:1 (local to host 43f61440) UUID : ef626106:1d36ec1d:dea584cc:2134df70 Events : 19 Number Major Minor RaidDevice State 0 8 146 0 active sync set-A /dev/sdj2 1 8 130 1 active sync set-B /dev/sdi2 2 8 178 2 active sync set-A /dev/sdl2 3 8 194 3 active sync set-B /dev/sdm2 4 8 2 4 active sync set-A /dev/sda2 5 8 50 5 active sync set-B /dev/sdd2 6 8 98 6 active sync set-A /dev/sdg2 7 8 66 7 active sync set-B /dev/sde2 8 8 34 8 active sync set-A /dev/sdc2 9 8 82 9 active sync set-B /dev/sdf2 10 8 18 10 active sync set-A /dev/sdb2 11 8 114 11 active sync set-B /dev/sdh2 /dev/md/data-0: Version : 1.2 Creation Time : Thu Oct 8 17:31:57 2015 Raid Level : raid6 Array Size : 21435290624 (20442.29 GiB 21949.74 GB) Used Dev Size : 1948662784 (1858.39 GiB 1995.43 GB) Raid Devices : 13 Total Devices : 12 Persistence : Superblock is persistent Update Time : Fri Jun 14 08:57:17 2019 State : clean, degraded Active Devices : 12 Working Devices : 12 Failed Devices : 0 Spare Devices : 0 Layout : left-symmetric Chunk Size : 64K Consistency Policy : unknown Name : 43f61440:data-0 (local to host 43f61440) UUID : 5158a2f3:ff19d5b2:90822650:9b53ac56 Events : 10717368 Number Major Minor RaidDevice State 0 8 131 0 active sync /dev/sdi3 1 8 147 1 active sync /dev/sdj3 2 8 179 2 active sync /dev/sdl3 3 8 195 3 active sync /dev/sdm3 12 8 3 4 active sync /dev/sda3 15 8 19 5 active sync /dev/sdb3 6 8 51 6 active sync /dev/sdd3 7 8 99 7 active sync /dev/sdg3 17 8 83 8 active sync /dev/sdf3 13 8 115 9 active sync /dev/sdh3 16 8 35 10 active sync /dev/sdc3 11 8 67 11 active sync /dev/sde3 - 0 0 12 removed
- StephenBJun 14, 2019Guru - Experienced User
21435290624 blocks super 1.2 level 6, 64k chunk, algorithm 2 [13/12] [UUUUUUUUUUUU_] md0 : active raid1 sdi1[0] sde1[11] sdc1[16] sdh1[13] sdf1[17] sdg1[12] sdd1[6] sdb1[15] sda1[4] sdm1[3] sdl1[2] sdj1[1] 4190208 blocks super 1.2 [13/12] [UUUUUUUUUUUU_]Yes, the RAID groups still show a removed disk.
It is possible to fix that using the linux command line (using mdadm). But it might be better to have paid netgear support (my.netgear.com) do that for you.
