givememynamebak
May 30, 2021Luminary
ReadyNAS SDK - Error & Proper removal
Hi - I could use some help. I want to build a .deb file, so I followed all the directions in the SDK. When I try to build, I get this error: root@ReadyNAS:~/sdk/examples# ./build.sh
E: Failed ...
givememynamebak
So these are the step's I've taken to remove, can anyone tell if I missed something to get my space back? I went from 87% full root volume to %64 full.
$ schroot -c R6 sudo -- apt remove libxml2-dev libsqlite3-dev pkg-config libsystemd-daemon-dev devscripts $ schroot -c R6 sudo -- apt remove build-essential $ schroot -c R6 apt -- remove sudo $ vi /etc/schroot/schroot.conf -- and removed contents $ sudo apt remove schroot $ rm -rf /chroot $ apt remove debootstrap
$ reboot
Is there anything additional I can do for cleanup to maximize my space back on root volume?
