tkernaghan
Oct 27, 2019Tutor
Slow internet speed
I have a ReadyNAS 312 and currently have the ReadyCloud app v1.19 running on my system. I am the only user of the ReadyNAS and use it for backup and storage. When the app is indexing or uploading f...
Oct 29, 2019Guru - Experienced User
tkernaghan wrote:
THERE IS NO NETWORK CONGESTION.
I am thinking you simply don't understand what I meant by network congestion. If ReadyDrop is using 100% of your bandwidth, then ReadyDrop is causing the network congestion. I wasn't implying that something else you were doing was causing it - I just wanted to see the data. Another possibility was that ReadyDrop was bogging down your machine - which doesn't seem to be the case, based on your screen shots.
tkernaghan wrote:
Interestingly, I can stream TV on my Roku TV without any issues.
This suggests that the issue might be local. After all, if the surface is using all your internet bandwidth, then you wouldn't be able to stream over the internet to the Roku. Task Manager is measuring everything that the surface is sending and receiving - including traffic that is going directly to your NAS, and not actually going over the internet. Note that the units are megabits per second (Mbps) - not megabytes (MBps).
Also, the network connection percentage shown in Task Manager is the percentage of the ethernet (or wifi) connection. Windows has no idea what your internet connection speed is. If the surface is actually negotiating full gigabit speeds, then ReadyDrop should be showing 100 Mbps and 10% utilitization, not 100%.
All this suggests that the surface might be running fast ethernet (100 mbit) for some reason - and not gigabit. So we should check on that possibility next.
- Can you tell us more about your home network setup? Is the NAS or Surface connected to an ethernet switch, or are they both connected directly to the Google router? If there are switches, can you give us the manufacturer/models?
- Also, are you using Cat 5e or better cabling? Ordinary Cat 5 would explain the issue, since that can't run gigabit. The cable grade should be printed on the ethernet cables.
- Can you check the ethernet speed on the Surface (when wired)? Enter "network connections" in the windows search bar and open the "view network connections" control panel app . Then select the ethernet connection, and click on "view status of this connection". That should give you a pop-up that shows the negotiated connection speed (along with some other information). It'd be helpful to see a screen shot of that pop-up.
tkernaghan
Nov 05, 2019Tutor
With respect to a wired connection and speed, a Surface technially doesn't have a wired connection to the machine itself. The only wired connection available is thorough the "dock" attached to the power supply. I've tested the issue via wi-fi and wired (through the dock) and it's the same result. Google Fiber was here, including bringing in a senior supervisor, for hours and the only conclusion was ReadyCloud was the culprit.
As I've mentioned before, if I'm working remotely (ReadyCloud is connected via VPN) there is no issue. It's only when I'm connected to ReadyCloud locally.
- SandsharkNov 05, 2019Sensei
Do you use virtual machines or any type of "containers" (like VeraCrypt) where a change to a single file may make ReadyCloud think the entire virtual drive or other container needs to be updated? Are you sure you have not inadvertently included your swap file in the file list? How about temporary files and cookies?
As I said in my last post, I think this may come down to ReadyCloud just needing to do too much. Short segments of what you are seeing are likely normal, but nothing continuous.
- schumakuNov 06, 2019Guru - Experienced User
tkernaghan wrote:As I've mentioned before, if I'm working remotely (ReadyCloud is connected via VPN) there is no issue. It's only when I'm connected to ReadyCloud locally.
This does again push the subject on the Google Fiber router when it has to handle massive trafic WLAN<->LAN and LAN<->LAN.
- StephenBNov 06, 2019Guru - Experienced User
tkernaghan: Can you also give us the Surface link speed when it is wired? Also, can you confirm that the problem still occurs when you are wired?
Also, when the problem happens, are you trying to use your web browser? Or is the problem happening with Outlook?
