forestpct
Sep 17, 2015Guide
ReadNas Duo V1 - LMS and ReadyDNLA queries
Have a ReadyNas Duo V1 with RAIDiator V4.1.14 firmaware installed. Have Logitech Media Server Add-On at 7.7.2 installed and ReadyDLNA is shown as V1.1.4. Both components work fine with Squeezebox Duet and Radio and various DLNA ready TVs but have two questions:
- I see there is a LMS V7.7.5 available for download from http://www.mysqueezebox.com/. Is that OK for use with my Duo?
- The Netgear support site lists a ReadyDLNA Add-on at V1.1.1.2 dated 2014/01/16. Is this a later version than the (embedded?) version I have installed already?
Thanks for any help/guidance.
If it is for the Duo v1 (Sparc) then yes it should work.
1.1.4 is the latest version for your Duo v1: https://community.netgear.com/t5/Using-your-ReadyNAS/ReadyDLNA-Update-Addons-Updated-2014-11-13/td-p/653608
1 Reply
- mdgm-ntgrNETGEAR Employee Retired
