Pimmit1's avatar
Pimmit1
Ready loud for Android not loading pictures
When using the ReadyCloud app on my Galaxy Note 10+ it will not load pictures. It shows the thumbnail but when I click on a picture it just loads a black screen.
  • JohnCM_S's avatar
    JohnCM_S
    NETGEAR Employee Retired
    Hi Pimmit1,
    Welcome to the Community!
    Have you tried uninstalling and re-installing the app?
    If you have another Android device, can you try the ReadyCLOUD app there and see if you will encounter the same issue?
    • Pimmit1's avatar
      Pimmit1
      Thanks for reaching out... But yeah, I've cleared cache/data and uninstalled/reinstalled numerous times. I have also tried on a note 8 and a galaxy A71 5g... None of which work properly. I guess when an app only has 2.2 stars it's about what I can expect...
ProSupport for Business
