jglazer63
Aug 29, 2019Tutor
ReadyNAS 424 Dropbox Sync
Is there a way to have Ready NAS automatically download dropbox updates? I know there's a setting for download sync that does virtually nothing. At least not after a while. I've had files on Dropb...
- Sep 02, 2019
Welcome to the Community!
NAS will automatically be updated if there are changes on your Dropbox folder that is chosen when you setup the Cloud service, you will have to choose Bidirectional or download Dropbox changes only. Do you have ReadyCloud service enabled as well?
You should also check if you have Both Internet and Services enabled by getting two Green checks on top of the Cloud services option. There should also be a green dot beside the Dropbox icon that serves as an indicator that Dropbox cloud is enabled on your NAS. I have my Dropbox setup on my NAS and it works fine until now.
HTH
Regards
Marc_V
Sep 02, 2019NETGEAR Employee Retired
HTH
Regards
- jglazer63Sep 02, 2019Tutor
I just enabled ReadyCloud. Not sure why that would effect drop box but ok.
I do have it set to bidirectional sync
Bot checks are green at the top of could services
