zimmfor's avatar
zimmfor
ReadyNAS 424 Egnyte Compatabilty
Hello,   We are using ReadyNAS RN312 with Egnyte storage sync but we are looking to upgrade to the RN424 model and continue to use Egnyte. I am curious if anyone has setup Egnyte on the 424 model...
  • StephenB's avatar
    Mar 25, 2019
    zimmfor wrote:
    Swapping the drives would work on both ReadyNAS but not sure that's the option we want to go.
    I'm not sure I understand that you mean by "swapping the drives would work on both ReadyNAS".   OOM-9 was just pointing that you could simply migrate your existing disks to the new NAS, and either retire or re-purpose the old one. You could of course also start over with new disks, and reinstall everything again.
    One aspect is that Egynte recommends 4-8 GB of RAM in the NAS here: https://helpdesk.egnyte.com/hc/en-us/articles/201638494-Storage-Sync-for-NETGEAR-Installation  Both your RN314 and the RN424 have only 2 GB of RAM.  So it might be wise to upgrade to an RN524 - that has 4 GB of RAM so it does meet Egynte's current specs.
ProSupport for Business
