scravatt
Jan 31, 2023Apprentice
Readynas 51600
The ReadyCloud IOS app is broken. It does not work on IOS 16.2 or higher. It logs in, shows my devices and just hangs. I know it worked specifically on IOS 15.7.3. It broke somewhere around IOS 16.2...
Sandshark
Jan 31, 2023Sensei
ReadyCloud is being taken out of service next month, so it is highly unlikely that anything will be done with the app at this point.
In what way are you using ReadyCloud (so alternatives can be suggested)?
scravatt
Feb 03, 2023Apprentice
I just use it to access files on my NAS remotely. I use the IOS app to do that when I'm mobile. It works on IOS 16.2 but not on 16.3. Probably a simple fix to get it working.
