Mr_1024
May 20, 2019Aspirant
ReadyNAS backup devices allow SSDs?
I need a small-scale "home" backup device. Do the RN212/312/422 allow SSD drives?
Why is it so difficult to find an answer to an easy question?
JMG
Marc_V
May 21, 2019NETGEAR Employee Retired
Hi Mr_1024
Welcome to the Community!
Yes, ReadyNAS OS 6 units very much accepts and allows the use of SSD drives, you can check the drives that has been tested on the Hardware Compatibility list.
Hope this helps!
Regards
- StephenBMay 21, 2019Guru - Experienced User
Also, the hardware manual shows how to mount them in the disk trays - see pages 171-174 here: http://www.downloads.netgear.com/files/GDC/READYNAS-100/ReadyNAS_%20OS6_Desktop_HM_EN.pdf
