canand
Aug 18, 2020Aspirant
ReadyNAS is not backing Java Files
Hi ReadyNas is not backing my Java files in Java Package. Appreciate any help if there is specific configurations to be done. Thanks in advance, be Safe Chetan
Aug 18, 2020Guru - Experienced User
How exactly are you backing up? Are you using ReadyCloud sync? Or some other method?
- canandAug 18, 2020Aspirant
Thanks for reply, Yes, I am using ReadyCloud Sync. Also, I noticed all timestamp are not preserved as per original source and Since we are using GIT and SVN, folders related to these are also not backed.
Thanks in advance
- StephenBAug 18, 2020Guru - Experienced User
That's not something I use, so I don't know what it's limits are.
There are other tools out there you could try (some are more flexible than ReadyCloud sync - handling multiple folders, etc).
Thanks, Appreciate if you could recommend any tool to go with?
