LeoCarlsson
Sep 15, 2018Follower
ReadyNAS Pro 2 - no access
ReadyNAS Pro 2
Hi all I have a perfect couple of working ReadyNAS Pro 2 and running readynas replicate an its working find ,until i had to factory reset one of them ,and now i can not activate it...
Sep 15, 2018Guru - Experienced User
Support can reactivate your license. Hopefully a mod here will help - perhaps JohnCM_S ???
But Replicate is being discontinued at the end of this year, so you will soon need to find an alternative backup solution for it anyway. One option is to convert your Pro-2 to run OS 6, and switch to ReadyDR. You could also use rsync over ssh. Both would need DDNS and forwarded ports (since they aren't running over the ReadyCloud VPN). https://community.netgear.com/t5/Current-NETGEAR-and-Partners/ReadyNAS-Remote-Photos2-Replicate-End-of-Service-announcement/td-p/1380425
