bethjim
Jul 08, 2017Aspirant
Readynas Pro Business Edition - How to install libio-socket-ssl-perl ?
ReadyNAS Pro Business Edition - OS 6.7.5 Logitech Media Server (LMS) 7.9.1 I'm trying to run a plugin called Spotty in LMS but it fails with this error message: "Spotty requires the Perl module...
- Jul 08, 2017
You will need to enable SSH access and then use an SSH client such as Putty to connect to the NAS. Log in as user root using the admin password. Once there, do an apt-get update and then the apt-get command they gave you (without sudo, since you are already logged on as root).
You may also be able to do it via an app like Shell in a box, but I've not tried that.
Note that this will likely install the app in the root partition, which is of limited size on the ReadyNAS. If this app creates large databases and/or logs, that could cause issues with the OS partition filling up.
Sandshark
Jul 08, 2017Sensei
ABNL
Jul 19, 2017Guide
OK, I logged in with Putty. I tried to find the right command. Then this happens:
login as: root
[email protected]'s password:
Welcome to ReadyNASOS 6.7.5
root@ReadyNAS:~# apt-get update
Hit:1 http://egnyte-cdn.egnyte.com/storagesync/netgear6/en-us 6.7 InRelease
Get:2 http://security.debian.org jessie/updates InRelease [63.1 kB]
Hit:3 http://apt.readynas.com/packages/readynasos 6.7.5 InRelease
Ign:4 http://mirrors.kernel.org/debian jessie InRelease
Hit:5 http://mirrors.kernel.org/debian jessie Release
Fetched 63.1 kB in 2s (26.9 kB/s)
Reading package lists... Done
root@ReadyNAS:~#
I do not know what to do now? This is what I should do?
"and then the apt-get command they gave you (without sudo, since you are already logged on as root)"
Who are "they" and what is a "sudo" and what did they give me?
