rubberscorpio
Nov 06, 2012Aspirant
Readynas Public Link down?
My ReadynasPhotoII says my HostName for web forwarding is not registered. It has been registered for over a year. It appears the site linking to our servers is down. Anyone else having the same issue?...
ce34
Nov 27, 2012Aspirant
Hi , i don't know if all works fine for everybody but on my side things have changed but i'm still stuck with Phoyos II. When i use the Manage ReadyNas
Photo II function i get a status not ready and when i use the diagnose option i get the following
OK: All connection tests from ReadyNAS Photos II to UPnP Router and photos.readynas.com site have passed.
OK: Hostname nas-A0-51-80 is available.
Error: Fail to access Photos II (http://xx.yyy.zzz.ww:8086) from internet. (error=-2). If you disabled automatic configuration of UPnP router, please make sure port 8086 is forwarded to the NAS.
OK: Successfully found your public IP (xx.yyy.zzz.ww).
I have to tell you that of course i did not disable the automatic configuration of UPnP router that i rebooted both the router & the NAS more than one tilme .
Could you tell me what is the meaning of RC -2 from internet .
One more info: before to upgrade to 5.3.6 everything was fine with Photos II (about one month ago) and that i am at level 5.3.7 now
Txs for your help
Txs for your help
