rubberscorpio
Nov 06, 2012Aspirant
Readynas Public Link down?
My ReadynasPhotoII says my HostName for web forwarding is not registered. It has been registered for over a year. It appears the site linking to our servers is down. Anyone else having the same issue?...
Selle
Feb 11, 2013Aspirant
Hi all!
I got an answer for the quoted problem below from the Swedish support team and I'm gonna try and translate it so everyone understands.
"Hi!
We have been told by engineering that the problem with ReadyNas Photos 2 will be fixed with the next update for the NAS.
I'm sorry but I can't give you a date when the update is coming but we have to hope that it won't be to far away.
I will close this ticket now."
This answer could fit quite well since the problem started for me after I installed the latest firmware.
So lets keep our fingers crossed that a new firmware will be available soon and it will fix this problem.
"Hi!
ce34 wrote: Hi , i don't know if all works fine for everybody but on my side things have changed but i'm still stuck with Phoyos II. When i use the Manage ReadyNas
Photo II function i get a status not ready and when i use the diagnose option i get the following
OK: All connection tests from ReadyNAS Photos II to UPnP Router and photos.readynas.com site have passed.
OK: Hostname nas-A0-51-80 is available.
Error: Fail to access Photos II (http://xx.yyy.zzz.ww:8086) from internet. (error=-2). If you disabled automatic configuration of UPnP router, please make sure port 8086 is forwarded to the NAS.
OK: Successfully found your public IP (xx.yyy.zzz.ww).
I have to tell you that of course i did not disable the automatic configuration of UPnP router that i rebooted both the router & the NAS more than one tilme .
Could you tell me what is the meaning of RC -2 from internet .
One more info: before to upgrade to 5.3.6 everything was fine with Photos II (about one month ago) and that i am at level 5.3.7 now
Txs for your help
