JabbaTheHutt
Sep 10, 2012Tutor
ReadyNAS Surveillance Add-on v1.2 BETA
September 10, 2012 ReadyNAS Surveillance Add-on v1.2 BETA: Release Note: New functions: 1. Cross browser support * Support MAC browsers: Safari and Firefox * SUpport Windows bro...
JabbaTheHutt
Mar 15, 2014Tutor
If you are running a ReadyNAS OS 6 unit, you can install and upgrade the Surveillance app directly from the Apps tab within the local GUI. Available tab to install. Installed tab to see status and upgrade.
- Nov 24, 2016Retired_Member
