Aurshur's avatar
Aurshur
Readynas Ultra 6, Make command and other problems
Hi,
I am utterly hopeless with linux, I have been trying to a program called Ps3netsrv to enable me to mount ps3, blu ray and dvd isos over my network, however I'm utterly at a loss how to proceed.
My biggest issue is that I'm unable to use the make command, I've SSH'd in as rootand attempted to install it using apt-get install-build essential, but It's unable to find it. Is it something as simplistic as updating the sources file, or am I just too far out of my depth?
Cheers.
  • Hi, thanks for your prompt reply, upon entering that I'm greeted with
    nasghul:~# apt-get update
    Hit http://www.readynas.com 4.2.23/ Release.gpg
    Ign http://www.readynas.com 4.2.23/ Translation-en_US
    Hit http://archive.debian.org etch Release.gpg
    Ign http://archive.debian.org etch/non-free Translation-en_US
    Ign http://www.readynas.com 4.2.23/ Packages/DiffIndex
    Ign http://archive.debian.org etch/non-free Packages/DiffIndex
    Hit http://www.readynas.com 4.2.23/ Packages
    Hit http://archive.debian.org etch/non-free Packages
    Reading package lists... Done
    Following that I get the message..
    Building dependency tree
    Reading state information... Done
    Package build-essential is not available, but is referred to by another package.
    This may mean that the package is missing, has been obsoleted, or
    is only available from another source
    E: Package build-essential has no installation candidate
    So I'm at a bit of a loss :(
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    Perhaps update to 4.2.26 or the 4.2.27 RC and try again.
    What does your /etc/apt/sources.list look like?
  • The update didn't seem to help.
    How do I view my sources.list I've read that I'll need a terminal based text editor..which I can't install at the moment :(
  • Sorry, forgive my ignorance, this is way out of my comfort zone :oops:
    nasghul:~# cat /etc/apt/sources.list
    deb http://www.readynas.com/packages 4.2.26/
    #deb http://archive.debian.org/debian etch main
    I'm guessing it should be longer than that :lol:
    mdgm-ntgr
    No need to apologise. I had to learn about this too some years back.
    See the # at the start of the last line.
    You need to remove that e.g. using vi
    # vi /etc/apt/sources.list
    Lookup the MAN page for vi to see how to use it.
    You should find it very useful.
    After you have uncommented the line and saved your changes you can try again
    # apt-get update && apt-get install build-essential
  • Or if you don't want to use vi, just:
    echo "deb http://archive.debian.org/debian etch main" >> /etc/apt/sources.list
    That will add the line without the commented out portion.
  • And if you ever do want or need to use vi (it's worth knowing the basics, since vi is the one text editor that's practically guaranteed to be on any unix system you encounter), you might find this vi cheat sheet more useful than the man page.
ProSupport for Business
