Yann2
Mar 05, 2009Tutor
ReadyNAS Vault : great but overpriced!
Hi! Just saw the ReadyNAS Vault announcement : great news! Something I definitely need to really secure my data as my PC backups are, indeed, copied on my ReadyNAS Duo but still in the same locatio...
Yann2
Apr 06, 2009Tutor
StGeorge wrote: ...
In the meantime, I'll use a less expensive (though probably inferior) service.
Well, problem is... From my point of view, there is no similar alternative : i.e. using the easy-to-go Frontview UI for secured Online Backup.
As of today, we're "trapped" to massively costly online service. "Take it or leave it"
Btw, you might go for configuring some Secured FTP, using Linux commands (considering another Online Backup service accepting this kind of protocol, if any?).
But as far I understood it I don't expect to be able to handle Incremental Backups. Same goes for the FTP Backup feature from Frontview, btw. But I might be wrong here (quite limited knowledge on FTP capabilities)...
