Yann2
Mar 05, 2009Tutor
ReadyNAS Vault : great but overpriced!
Hi! Just saw the ReadyNAS Vault announcement : great news! Something I definitely need to really secure my data as my PC backups are, indeed, copied on my ReadyNAS Duo but still in the same locatio...
claykin
Apr 04, 2010Aspirant
You got it. That said, Vault is not designed to store all your NAS data. Its designed to store the most critical files and those files that change frequently. For media files you can do local backups and rotate them offsite. Or do NAS to NAS backup.
Anyone who wishes to store 100's or 1000's of GB of data in the cloud is best served by seeding the backup using a USB disk you send to the provider. Several online backup services offer the option for you to send your data via disk for the initial backup.
