Yann2
Mar 05, 2009Tutor
ReadyNAS Vault : great but overpriced!
Hi! Just saw the ReadyNAS Vault announcement : great news! Something I definitely need to really secure my data as my PC backups are, indeed, copied on my ReadyNAS Duo but still in the same locatio...
wagwar
Dec 16, 2010Aspirant
I see the 'advice' to "Backup your data" then "Install this" or "Swap the drive" or ...
My question is if I can't afford ReadyNas Vault and the on-line sites are too slow on my internet connection - other than buying another hard drive (that will eventually fail) what other backup media is practical for 1 TB + backup? Tape is old tech, unreliable and cartridges deteriorate with age, so tape is not an answer. What do other folks here use?
Thanks,
Thanks,
