Yann2
Mar 05, 2009Tutor
ReadyNAS Vault : great but overpriced!
Hi! Just saw the ReadyNAS Vault announcement : great news! Something I definitely need to really secure my data as my PC backups are, indeed, copied on my ReadyNAS Duo but still in the same locatio...
claykin
Feb 17, 2012Aspirant
sphardy wrote: Yes - search the forum here, there are full installation instructions
Requires SSH to be enabled and some command line work, but once running all is GUI controlled
Can someone (you) write a full Crashplan installer for the Readynas? Command line work for non linux users is daunting.
Frankly I'd prefer a Jungldisk solution. Jungledisk does a better job covering end user and business needs. They also have fewer restrictions on use. Finally, no Java!
