BartNijs
Jun 23, 2022Follower
ReadyNAS webinterface not showing all files and folders (max 100)
RN428, FW 6.10.7, RAID 5, 4 8TB Drives I have multiple shares with a lot of folders. I can see the folders in my explorer on Windows, but it looks like the number of folders/files that are shown in ...
Jun 23, 2022Guru - Experienced User
I have multiple shares with a lot of folders. I can see the folders in my explorer on Windows, but it looks like the number of folders/files that are shown in the web interface is limited.
Why are you using the web interface? Why not use File Explorer/SMB ???
BartNijs wrote:
I just counted and it seems like it show max 100 files/folders.
Are you using the web admin interface (browsing from the shares tab)?
I just checked, and I can see ~500 folders in one subfolder from both the web and file explorer. On the web I checked both "browse" and "recover". So I am puzzled by your info.
Note you do need to scroll to the bottom of the page if you have a lot of files - then it will add some more.
- May 25, 2022Retired_Member
