PaRau
Dec 28, 2016Follower
readynass surveillance and doorbird?
Hi, I just installed Readynas Surveillance on my readynas Ultra 6. Nu issues there. I would like to integrate my doorbird to this system? Doorbird is connected to the same network via LAN. I c...
FramerV
Dec 28, 2016NETGEAR Employee Retired
Hi PaRau,
I would think that the issue is with the camera's not being supported.
I have seen cases that they had issues with the camera as well as ones that do work like on this post.
You could probably try a different way of doing this. On the post above, he mentioned using zoneminder.
Unfortunately I do not have a step by step guide for it.
