tony359's avatar
tony359
Apprentice
Feb 11, 2022
IP camera surveillance set up
Hello all,
I've got a few Eufy cameras which allow me to record on the NAS but I am a bit puzzled on how to do so. I found the "surveillance add on" manual which suggests how to enable the add-on, but the directions seem to be incorrect.
Also... do I need to pay to enable that on my NAS???
Running OS6.10.6
Thanks for your help!
  • tony359 wrote:
    But I don’t want to keep my PC on 24/7, that’s what the Nas is for 🙂
    The cameras are basic and record 24/7 on their own SD card. It would have been nice to also have a copy on the NAS to be safe.
    Besides things that can go wrong, is there any other disadvantage in using a nas for this purpose? Drive wear and tear?
    Actually, that's what a DVR is for.  But you can use a dedicated PC as a DVR.  Assuming your cameras are of the "Eufy solo" type, I see only RTSP capability for streaming, so you'd have to look for that in any product you choose.  Blue Iris does support RTSP.  For a LInux solution, Shinobi looks promising (https://shinobi.video/ ), but I see nothing suggesting it's compatible with the older Debian of the ReadyNAS.  It does have a web interface, so can be run headless.
    No, I wouldn't recommend using your desktop PC for this, either.
    You haven't said which model NAS and cameras you have, but the older entry-level ones are certainly not up to keeping up with multiple simultaneous high-resolution streams.  As a backup of the video, so not in real time, they are excellent.  But I see nothing about a Eufy that suggests they have that capability.  The very outdated Debian core of the ReadyNASOS is probably going to be your largest stumbling block.
  • StephenB's avatar
    Readynas Surveillance was discontinued in 2017, so it is not an option.
    • tony359's avatar
      tony359
      Apprentice
      Thanks Stephen.
      Do you think I can set something up manually?
      • StephenB's avatar
        I don't know enough about Eufy cameras to say.
        Generally speaking, I suggest starting with a PC package (then storing the videos to the NAS from the PC software).
ProSupport for Business
