tony359
Feb 11, 2022Apprentice
IP camera surveillance set up
Hello all, I've got a few Eufy cameras which allow me to record on the NAS but I am a bit puzzled on how to do so. I found the "surveillance add on" manual which suggests how to enable the add-on...
- Feb 13, 2022
tony359 wrote:
But I don’t want to keep my PC on 24/7, that’s what the Nas is for 🙂
The cameras are basic and record 24/7 on their own SD card. It would have been nice to also have a copy on the NAS to be safe.
Besides things that can go wrong, is there any other disadvantage in using a nas for this purpose? Drive wear and tear?Actually, that's what a DVR is for. But you can use a dedicated PC as a DVR. Assuming your cameras are of the "Eufy solo" type, I see only RTSP capability for streaming, so you'd have to look for that in any product you choose. Blue Iris does support RTSP. For a LInux solution, Shinobi looks promising (https://shinobi.video/ ), but I see nothing suggesting it's compatible with the older Debian of the ReadyNAS. It does have a web interface, so can be run headless.
No, I wouldn't recommend using your desktop PC for this, either.
You haven't said which model NAS and cameras you have, but the older entry-level ones are certainly not up to keeping up with multiple simultaneous high-resolution streams. As a backup of the video, so not in real time, they are excellent. But I see nothing about a Eufy that suggests they have that capability. The very outdated Debian core of the ReadyNASOS is probably going to be your largest stumbling block.
Feb 11, 2022Guru - Experienced User
Readynas Surveillance was discontinued in 2017, so it is not an option.
- tony359Feb 11, 2022Apprentice
Thanks Stephen.
Do you think I can set something up manually?
- StephenBFeb 11, 2022Guru - Experienced User
I don't know enough about Eufy cameras to say.
Generally speaking, I suggest starting with a PC package (then storing the videos to the NAS from the PC software).
- SandsharkFeb 11, 2022Sensei
IMHO, running surveillance on a headless system like a NAS is not a wise move. If your cameras have FTP capability (used to be common, isn't so much any more), you can just have them write to the NAS using that. If not, I recommend you run the surveillance software on a PC and then use the NAS as long-term storage to offload the PC drive. Most surveillance software has that capability. Using the NAS a primary storage for a PC based surveillance system is also not a wise move, too much can go wrong and you end up with no recordings. I personally use Blue Iris.
