draghuram
Feb 15, 2025Aspirant
RN102 - Unable to create a volume of a USB disk
Hi, I connected a Seagate external hard drive (https://www.amazon.com/dp/B093BVQYYM) to my RN102. By logging into the RN102 using ssh, I can see that the device is recognized and I can even crea...
Sandshark
Feb 15, 2025Sensei - Experienced User
I recommend you format it on you computer as NTFS, not on the NAS as EXT. That way, you can still read your backup drive directly on the computer if the NAS fails.
draghuram
I can read it on my Linux machine so that is not a problem, thanks.
