DJL-Consulting
May 18, 2016Tutor
RN104 recent Update to 6.5.0 Deluge Download Folder Permission Problems
Hi All, Sorry to trouble you. But I am having some real problems with an App downloaded and installed from ReadyNas Xtras. The App, Deluge 1.3.12 has been fine after installing on my Netgeat RN1...
Shtoffen
May 22, 2016Aspirant
There is small problem, with backing up 2TB of data...
May 22, 2016Guru - Experienced User
Is your problem also related to the Deluge Download Folder? Or is it something else?
If the data is important to you, you should back it up. RAID is (in my experience) not enough to keep your data safe.
Though it is inconvenient/time consuming to restore all the data.
