DJL-Consulting
May 18, 2016Tutor
RN104 recent Update to 6.5.0 Deluge Download Folder Permission Problems
Hi All, Sorry to trouble you. But I am having some real problems with an App downloaded and installed from ReadyNas Xtras. The App, Deluge 1.3.12 has been fine after installing on my Netgeat RN1...
May 22, 2016Guru - Experienced User
Is your problem also related to the Deluge Download Folder? Or is it something else?
Shtoffen wrote:
There is small problem, with backing up 2TB of data...
If the data is important to you, you should back it up. RAID is (in my experience) not enough to keep your data safe.
Though it is inconvenient/time consuming to restore all the data.
DJL-Consulting
May 22, 2016Tutor
Sorry duplicate post, apologies there..... :smileyindifferent:
- StephenBMay 22, 2016Guru - Experienced User
DJL-Consulting wrote:
StephenB - My problem was with Deluge having access to the download folder, I would just get 'permission denied' error, no matter what I tried.
I was actually asking Shtoffen. It wasn't clear to me if his problem was the same as yours, or not.
- DJL-ConsultingMay 22, 2016Tutor
StephenB wrote:
DJL-Consulting wrote:StephenB - My problem was with Deluge having access to the download folder, I would just get 'permission denied' error, no matter what I tried.
No worries, but I thought (as I had a few minutes spare) I would post up on here about this as 'Deluge' was mentioned. Sorry for butting in, but (no pun intended there) it seems the new FW has stopped a lot of Apps, Services, etc. It certainly has for me anyway. I will look into it in more depth in the coming days......:smileywink:
