xtrips1's avatar
xtrips1
RNDP6000 Nzbget not working
Hello,
I just upgraded my machine to the 6.x firmware and chose to install the Nzbget app offered in this firmware. The app is quite old, version 17.1 but I wanted to try it anyway.
It simply does not work. I got to the point that my Usenet server passes the connection test but putting an nzb file in the monitored folder or adding it from the web interface does not cause any reaction.
The log just says "nzbget 17.1 daemon-mode"
Nothing else happens.
I am wondering, Does this Nzbget app still work? On an RNDP6000 upgraded to 6.x?
If not then is there a solution?
Thanks
ProSupport for Business
